issammesk Posted December 13, 2012 Share Posted December 13, 2012 hi sir thank you for your great efforts if you can make lisp for anguler dimension when i have profiles x scale 1-500 and y scale 1-50 and i want when draw anguler dimension take scale 1:1 x & y Quote Link to comment Share on other sites More sharing options...
MSasu Posted December 14, 2012 Share Posted December 14, 2012 Not sure that you really need an AutoLISP routine for that; you should achieve the same result by defining two dedicated dimension styles. Quote Link to comment Share on other sites More sharing options...
irneb Posted December 14, 2012 Share Posted December 14, 2012 As I'm understanding it, the OP's asking for an angular dimension to work on a drawing drawn with different X & Y scales. I don't think it's possible to do this "normally". I can think of 2 ways to try and go about this as work-arounds: Draw everything (including the dims) in a block, then change the block's x/y scale factors to simulate the X=1:500 and Y=1:50 (i.e. set X=0.1 and Y=1.0). Draw all on a UCS plane rotated around the Y-axis to (90 - (tan-1 (1/10))) = 84.289406862500357487304118651766 degrees You might need to adjust the text style's skewing factor and width factor so it looks correct. Quote Link to comment Share on other sites More sharing options...
