Autocad 2012 LT. I can't fillet between an existing line and arc. The line's start Z is 0 as well as middle and end are 0. The arc is the same....but still it says they are non coplaner and will not fillet.
In another area of the drawing, I draw an arc and a line and they will fillet just fine..... This is weird....
Edited to add..... I have gone back in to the properties and even though the say that the Z is 0, I type "0" in again and then it will fillet.....
Rounding error based on your units settings most likely. FILLET command luckily sees beyond that.
