1okskipper Posted December 14, 2012 Posted December 14, 2012 Autocad 2012 LT. I can't fillet between an existing line and arc. The line's start Z is 0 as well as middle and end are 0. The arc is the same....but still it says they are non coplaner and will not fillet. In another area of the drawing, I draw an arc and a line and they will fillet just fine..... This is weird.... Edited to add..... I have gone back in to the properties and even though the say that the Z is 0, I type "0" in again and then it will fillet..... Quote
pendean Posted December 15, 2012 Posted December 15, 2012 Rounding error based on your units settings most likely. FILLET command luckily sees beyond that. Quote
