jjatho Posted December 15, 2012 Share Posted December 15, 2012 Running AutoCAD 2013. I created a .dwt template for general use with plenty of a various paper space layouts and such. I also created a bunch of styles for text, dimensions, multileaders, and tables for both paper and model space. After saving the template, those styles will still be there any time I open up a new drawing with that template. After working a bit and then saving the drawing, the styles will all be gone once I open it again. Re-opening the original template always has all of the old styles still saved, so why would they disappear once I use that template on a drawing? Quote Link to comment Share on other sites More sharing options...
Organic Posted December 15, 2012 Share Posted December 15, 2012 Are you purging and removing the unused styles inadvertently? Quote Link to comment Share on other sites More sharing options...
jjatho Posted December 15, 2012 Author Share Posted December 15, 2012 Ah that makes perfect sense. I use PURGE all the damn time. It didn't occur to me that it would be removing unused styles. Is there a way to protect unused styles from being purged? Quote Link to comment Share on other sites More sharing options...
Dadgad Posted December 15, 2012 Share Posted December 15, 2012 (edited) You can change your preference in the PURGE dialog to confirm items to delete. You may do better by changing your ISAVEPERCENT, instead of running purge in the middle of your drawing. I too use a template full of the usual suspects. Use the -PURGE (include the hyphen) command at the commandline when the drawing is finished. First purge the REGAPPS. Then repeat the command using the ALL option. AUDIT, choose Yes for fix problems. Set your ISAVEPERCENT to 0, and do a final clean save, which will make the file as lean as possible. As you have already found running PURGE before its time will only cause you problems, there is no upside. Edited December 15, 2012 by Dadgad Quote Link to comment Share on other sites More sharing options...
Organic Posted December 15, 2012 Share Posted December 15, 2012 You could always put those styles into your titleblock (mtext objects containing a single dot that is then hidden below some other part of your titleblock etc). Quote Link to comment Share on other sites More sharing options...
