marinebro0306
Wrapping Text?
marinebro0306
Hi,
I am modeling a hotel pen, and all I have left is the text. On the shaft of the pen, it says
THE
TALBOTT
HOTEL
From the top of "THE" to the bottom of "HOTEL" is about a third of the way around the shaft of the pen. Is there any way to wrap the text around the shaft, or any other means of doing this?
Thanks!
Share this post
Link to post
profcad
If you are modeling the pen, then the text could be a graphic file that you use as a material and apply it to the surface of the pen.
Share this post
Link to post
marinebro0306
Thanks, I figured it out though.
(make a .bmp or jpg, and incorporate it as a decal)
Share this post
Link to post
Aardvark
You can also just type the text in and then use the emboss tool to wrap the text onto the surface.
Share this post
Link to post
marinebro0306
I tried that, but it makes an imprint rather than a decal type of thing.
Share this post
Link to post
Mr T
Change it so it goes 'down' a small amount eg 0.001mm
Nick
Share this post
Link to post
marinebro0306
Yeah I tried that too, but the inside of the letters were hollow instead of filled (just showed the outline of the letters)
Share this post
Link to post
Aardvark
What font are you using? Are you emboss or engrave within the emboss tool?
Share this post
Link to post
CCHESTER
How Can I Wrap Text Around A Vessel? Like A Tank Number? I Am Not Familiar With This Emboss Tool
Share this post
Link to post
CCHESTER
How Can I Do This
Share this post
Link to post
shift1313
You have to create a 2d sketch away from the part. In the sketch insert your image(i believe it must be a .bmp and i use 24bit). Exit the sketch and click the Decal button. It will ask you to select an image(your sketch), then you will have a wrap to face option, select that and then your cylindrical face.
The decal orientation is decided by the position of your image in the sketch. I know this has been covered in this forum because I have uplaoded an image before. at the bottom of the page there should be "similar threads" and you can also use the search function and should get a more detailed answer. If you cant find it let me know.
Share this post
Link to post
JD Mather
How Can I Do This
Attach your file here.
Share this post
Link to post
