hi , i create txt file with point coordinates (x , y) , how i can to import this file and program will draw a line ?coordinates.txt
You will need to use a Script.
Plenty of examples on CADTutor.
Use search function.
You probably do not even need a script.
First of all format your coordinate file so that there are no spaces between numbers, and no odd tabs outside the text, and keep that file open (using Notepad or Wordpad).
1569.0995,1443.7471
1500.6247,1454.0031
1302.0477,1491.6086
1161.6744,1517.8185
1093.1996,1530.3537
Start the "Line" command, and when the command line wants the first point, highlight and copy all your points from the text file, and then paste into the command line. The line is drawn :D
