j_spawn_h Posted December 26, 2012 Posted December 26, 2012 I want to label multiple lines using the dimensions based off their lengths. I want to select mutliple lines and the ones that are close to each of their lengths be labeled. If i have 4 lines that are 4'-0" then 2 lines that are 6'-0" then 3 more 4'-0". I would select all of them then it would label them perpendicular to the lines. The 4 - 4'-0" would have one label, then the 2-6'-0" would be labeled with one label, then the 3-4'-0" would be labeled with one label. If i did not give enough info let me. Quote
