Mbeis
DXF 3D Anatomy
Mbeis
Can anyone help me find a good resource on how to create a 3D DXF file from scratch? I am a developer working on a tool that can create cylindrical shapes from schematic drawing coordinates.
Share this post
Link to post
BIGAL
Maybe a simpler way looking at this yesterday just use VL commands to create 3d objects using lisp is it really needed to use DXF.
this is the VBA
RetVal = object.AddCylinder(Center, Radius, Height)
lisp
(vla-AddCylinder Center Radius Height)
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(setq mspace (vla-get-modelspace doc))
(setq pt1 (vlax-3d-point (getpoint "\nCenter point: ")))
(setq rad (getreal "\nRadius: " pt))
(setq hgt (getreal "\nHeight: " pt))
(vla-addcylinder mspace pt1 rad hgt)
Edited by fuccaro
Just closing a CODE tag
Share this post
Link to post
Tyke
I assume your tool does not work within AutoCAD. If I'm right read on, but if your tool does work within AutoCAD look at what BIGAL said and save the resulting drawing as a DXF file.
If you want to create a DXF file have a look at this article from Paul Bourke http://paulbourke.net/dataformats/dxf/min3d.html
A DXF file can be very large and its must be syntactically perfectly correct or you will not be able to open it. A missing line of code will be fatal.
Share this post
Link to post
