NOT SURE HOW TO RUN LISP C/W DCL ?? IT WONT RUN PROPERLY WITH OUT DCL ANY ONE KNOW WHY AND HOW TO FIX ?? WHERE SHOULD I PUT DCL AND LISP FILES ??
;Tip1758a:  DD_CHS.LSP       Change Text Style          (C)2001, Colin Mitchell
(defun
  C:CHS (/ OLD_ERROR OLD_CMDECHO TEXTENTITIES DCL_ID TEXTSTYLE_LIST
         TS_LIST TABLE_CHECKER DO_IT_UP ENTITY_INDEX NEW_STYLE
 (defun ERERROR () (command ^C^C) (setq *ERROR* OLD_ERROR) (princ))
 (setq OLD_ERROR *ERROR*)
 (setq *ERROR* ERERROR)
 (setq OLD_CMDECHO (getvar "cmdecho"))
 (setvar "cmdecho" 0)
 (princ "\nSelect text objects: ")
 (setq TEXTENTITIES (ssget (list (cons 0 "TEXT"))))
 (while (null TEXTENTITIES)
   (princ "\nPlease select some text.")
 ) ;end while
   (if TEXTENTITIES
       (if (not AI_UTILS)
         (load "ai_utils")
       ) ;_ end of if
       (setq DCL_ID (load_dialog "DD_chs.dcl"))
       (if (not (new_dialog "ChangeStyle" DCL_ID))
         (alert
           "\nCannot load.  Dialog file DD_CHS.DCL was not found."
         ) ;_ end of alert
       ) ;_ end of if
       (defun
          TEXTSTYLE_TABLE ()
         (setq TEXTSTYLE_LIST (AI_TABLE "STYLE" 4))
         (setq TS_LIST (itoa (length (AI_TABLE "STYLE" 4))))
       ) ;_ end of defun
       (TEXTSTYLE_TABLE)
       (cond
         ((/= TS_LIST "0")
          (setq TEXTSTYLE_LIST (acad_strlsort TEXTSTYLE_LIST))
          (start_list "textstyle_list")
          (mapcar 'add_list TEXTSTYLE_LIST)
          (end_list)
       ) ;_ end of cond
       (setq TABLE_CHECKER 0)
       (defun
          CHECK_IT ()
         (if (= TABLE_CHECKER 0)
             (setq DO_IT_UP 1)
             (set_tile "message" "Please select a text style.")
           ) ;_ end of progn
         ) ;_ end of if
         (if (= DO_IT_UP 0)
           (done_dialog 1)
         ) ;_ end of if
       ) ;_ end of defun
       (action_tile "accept" "(setq do_it_up 0)(check_it)")
       (action_tile "cancel" "(setq do_it_up 1)(done_dialog)")
       (action_tile "info" "(info)")
       (action_tile "how" "(how_to)")
       (action_tile "about" "(about)")
       (action_tile
         "textstyle_list"
         "(setq entity_index $value)(setq table_checker 1)"
       ) ;_ end of action_tile
       (setq EXECUTE_IT (start_dialog))
       (unload_dialog DCL_ID)
       (if (= EXECUTE_IT 1)
           (setq ENTITY_INDEX (read (strcat "(" ENTITY_INDEX ")")))
           (foreach
              I ENTITY_INDEX
             (setq NEW_STYLE (nth I TEXTSTYLE_LIST))
           ) ;_ end of foreach
             (setq TELOOP 0)
             (setq TELENGTH (sslength TEXTENTITIES))
             (repeat TELENGTH
               (setq TEENTITY (ssname TEXTENTITIES TELOOP))
               (setq TEEVAL (entget TEENTITY))
               (setq
                 TEEVAL
                  (subst
                    (cons 7 NEW_STYLE)
                    (assoc 7 TEEVAL)
                    TEEVAL
                  ) ;_ end of subst
               ) ;_ end of setq
               (entmod TEEVAL)
               (setq TELOOP (+ 1 TELOOP))
             ) ;repeat
             (prompt (strcat "\nText style set to: " NEW_STYLE))
         (princ "\nNo changes were made.")
       ) ;end execute_it
 (setvar "cmdecho" OLD_CMDECHO)
) ;_ end of defun
;;end of file
put both in a support file search path for autocad
Im in support folder now how do i link button to dcl to lisp ???
the button is created already in a toolbar but when i use it it says
_chs Unknown command "CHS".
please explain more how to connect
Did you load the .lsp first?
type this at the command line, then try CHS
(load "DD_CHS")
//Tip1758b:  DD_CHS.DCL       Change Text Style          (C)2001, Colin Mitchell
dcl_settings : default_dcl_settings {audit_level=0;}
ChangeStyle : dialog {label="Change Text Style";
spacer;
:row {
:column {
 :boxed_column {label="Available Text Styles:";
   :list_box {key="textstyle_list";
    width=35;
    fixed_width=true;
    height=10;
    fixed_height=true;
    allow_accept=true;
    multiple_select=false;}
spacer;
}//end boxed_column
:text {key="message";edit_width=10;alignment=centered;}
}//end column
: column {
:spacer {height = 0.125;}
:button {label = "OK";
  key = "accept";
  is_default = true;
  fixed_width=true;
  width=11;}
     :button {label = "Cancel";
  key = "cancel";
  is_cancel = true;
  fixed_width=true;
  width=11;}
:spacer {height = 10;}
}//end column
}//end row
}//end of file
nicely done friends. yes yes yes .
The lisp 'calls' the DCL, you don't need to 'link' them. As stated before "put both in a support path for Autocad"
swell . the lisp calls it
which part could i remove /add if i didnt want call to dcl ??
(defun
  C:CHS (/[code] OLD_ERROR OLD_CMDECHO[/code]
[code];;;;;;;
;;;;;;;[/code]
  ) ;end while
    (if TEXTENTITIES
        (if (not AI_UTILS)
          (load "ai_utils")
        ) ;_ end of if
          (alert
          ) ;_ end of alert
        ) ;_ end of if
        (defun
           TEXTSTYLE_TABLE ()
        ) ;_ end of defun
        (TEXTSTYLE_TABLE)
        (cond
          ((/= TS_LIST "0")
           (end_list)
        ) ;_ end of cond
        (defun
           CHECK_IT ()
              (setq DO_IT_UP 1)
            ) ;_ end of progn
          ) ;_ end of if
          (if (= DO_IT_UP 0)
            (done_dialog 1)
          ) ;_ end of if
        ) ;_ end of defun
        (action_tile
          "textstyle_list"
            (foreach
               I ENTITY_INDEX
            ) ;_ end of foreach
              (setq TELOOP 0)
              (repeat TELENGTH
                (setq
                  TEEVAL
                   (subst
                     (cons 7 NEW_STYLE)
                     (assoc 7 TEEVAL)
                     TEEVAL
                   ) ;_ end of subst
                ) ;_ end of setq
                (entmod TEEVAL)
              ) ;repeat
        ) ;end execute_it
[code]      ) ;
 (princ)[/code]
) ;_ end of defun
;;end of file
I found one similar at
Jeffery P Sanders .com (CTS)
but both dont allways work like i want i wanted to change text to standard ... it's out of date code i think ??
see attached
Drawing1.dwg
