fatdaddy Posted November 11, 2008 Share Posted November 11, 2008 Hi all We have been using AutoCAD 2000 for a few years, albeit for simple layout drawings. I have come across a problem today which has baffled me. I wish to copy objects from one drawing file to another and have done so with no problems in the past. I am working from a building layout supplied by a client and wish tyo copy part of the drawing to my revised drawing file. I selected the objects, used the copy command, switched drawing windows and used the paste command. I get the 'pasteclip' in the command line but nothing is deposited into the current file. I have checked that the current layer is not turned off, tried good old DOS command lines (ctl +c, ctl + v), changed the original drawing properties from read only but nothing works. What am I missing? Any help gratefully received!! Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 11, 2008 Share Posted November 11, 2008 Does your client have a more recent version of AutoCAD than you do requiring him to save his drawing in 2000 format? Quote Link to comment Share on other sites More sharing options...
fatdaddy Posted November 11, 2008 Author Share Posted November 11, 2008 Good point, I think the drawing may have been saved as lt/2000 prior to being sent to me. How does this affect the copy command? Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 11, 2008 Share Posted November 11, 2008 Some glitch introduced when saving a file "back to" a previous version. It may have applied to more than one release of AutoCAD. I think I recall 2007 being specifically mentioned. Quote Link to comment Share on other sites More sharing options...
fatdaddy Posted November 11, 2008 Author Share Posted November 11, 2008 Thanks, I'll check in the morning. Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 11, 2008 Share Posted November 11, 2008 Here you go: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7450124&linkID=9242019 Quote Link to comment Share on other sites More sharing options...
soleary Posted November 11, 2008 Share Posted November 11, 2008 Here you go: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7450124&linkID=9242019 Nice post ReMark. Didn't hear of that before - then again I skipped 2007 Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 11, 2008 Share Posted November 11, 2008 Thanks soleary. Probably just a piece of useless information floatin' around inside this ol noggin. Quote Link to comment Share on other sites More sharing options...
soleary Posted November 11, 2008 Share Posted November 11, 2008 Thanks soleary. Probably just a piece of useless information floatin' around inside this ol noggin. No, it's good info. Fair play. Quote Link to comment Share on other sites More sharing options...
