sbadguy7 Posted January 13, 2013 Share Posted January 13, 2013 hey, please answer this thread quickly... i wanna ask, last night, i tried to make a 3D wall, after i union the 3 solid materials, all of them is good, but it still left a lines, do you know why?, thx Quote Link to comment Share on other sites More sharing options...
Dadgad Posted January 13, 2013 Share Posted January 13, 2013 Welcome to CADTutor. Check your SOLIDHIST variable setting, sounds like you want it set to 0 Enter SOLIDHIST at the commandline, to see what the current variable setting is, and if need be, reset it to 0. You should probably check out the PSOLID (polysolid) command, as it enables you to create a 3D wall like solid as easily as drawing a polyline. You can set the height and thickness, as well as the justification of the solid before you start drawing your wall, just follow the prompts at the commandline. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted January 13, 2013 Share Posted January 13, 2013 Attach the file here that exhibits this behavior. Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 13, 2013 Share Posted January 13, 2013 What is the system variable DELOBJ set to? Maybe those "lines" are your base geometry. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted January 14, 2013 Share Posted January 14, 2013 What is the system variable DELOBJ set to? Maybe those "lines" are your base geometry. That's the one I was trying to remember, but couldn't! Quote Link to comment Share on other sites More sharing options...
