AutoCAD Electrical Custom icons
I have created a few custom icons, for ACADE, and when i right click to edit the tag etc, i have a field in show/edit miscellaneous for putting an EX rating in, in this case its EXIA, i have already added say 15 instruments but i want to add EXIA in to the field in bulk, is there a way to do that or can you only edit stuff one by one?
thanks
assuming you mean block not icon, you can select all the blocks that you need to edit and change the attribute value in the properties palette.
Maybe i dont know the correct term but basically its a an eletrical component that i select from the icon menu and then add the likes of a tag discription etc, so i cant get to the properties as when i right click it brings the acade component editor up
A block is an item in the drawing, an icon is an item on a menu. I assumed you were selecting a group of items already in the drawing.
You don't need to right click. Select your items with a left click and then access the properties palette (get it on screen before selection if necessary). If you need to modify them whilw still on the menu then I can't help, ACADE2011 must be different to ACADE2013.
