Tyke Posted January 21, 2013 Posted January 21, 2013 A 2013 version should be able to recognise a 2011 CUIX file. You must EXPORT the Workspace from 2011 and then Import it into 2013. Have you followed the link in post #12? Quote
Ski_Me Posted January 21, 2013 Author Posted January 21, 2013 Ok I figured it out, export the classic from 2011 to a easy to locate folder, then import the file to 2013 and transfer and set as current otherwise both the ribbon and the classic interface will be displayed. Quote
Ski_Me Posted January 21, 2013 Author Posted January 21, 2013 A 2013 version should be able to recognise a 2011 CUIX file. You must EXPORT the Workspace from 2011 and then Import it into 2013. Have you followed the link in post #12? No I did not follow the link but I'm pretty sure I followed the instructions. Quote
Sparky Posted May 23, 2013 Posted May 23, 2013 I have adapted to the ribbon well and try to use the keyboard shortcuts as much as possible. However, we have a new employee starting at our office next week who will be using AutoCAD 2013 Lite. I have been able to use the classic workspace in 2013 and get the toolbars to show up but the icons are blank. Anyone else have this problem? Thanks for the help. Quote
Sparky Posted May 23, 2013 Posted May 23, 2013 How would I reset the profile? Even when I go back to my user defined workspace that has my customized ribbon and toggle on the toolbars I get the same results. Quote
ReMark Posted May 23, 2013 Posted May 23, 2013 Yeah, I kinda of thought you would. Thanks for the update. Quote
