General_T Posted January 26, 2013 Posted January 26, 2013 Hi, I just want to have a planet continuously rotating at a constant speed. So I have the animation loop set from frame 0 - frame 100. But as I start the animation the speed is not constant - it starts a bit slow - then gets to speed - then as it approaches frame 100 it starts to slow again. How do you get it to maintain a steady rotation speed throughout the loop? Thanks Again Quote
Raudel Solis Posted January 27, 2013 Posted January 27, 2013 select your spinning trinket and then look up and find graph editors then select either dope sheet, or curve editor. that is what you need to use to keep rotation continuous. play around with it. Quote
