What command to use in assembly drawing ...
Catherine Ding
The case is I want move like a object like a screw out or in in the some assembly so to fit the place where it should go , I hope the screw could be an whole object instead of multible lines. The benefit is just to make the modification easier. Does anyone know how to make it easier ?:)
Use the BLOCK command on your screws, it combines all drawing entities (lines, arcs, circles etc) into one entity called a block. You can then use the insert command to insert it as many times as required in your drawing.
