Catherine Ding Posted February 12, 2013 Posted February 12, 2013 The case is I want move like a object like a screw out or in in the some assembly so to fit the place where it should go , I hope the screw could be an whole object instead of multible lines. The benefit is just to make the modification easier. Does anyone know how to make it easier ? Quote
Catherine Ding Posted February 12, 2013 Author Posted February 12, 2013 waiting for the answer. I am a newbie Quote
Mike_Taylor Posted February 12, 2013 Posted February 12, 2013 Is this a 2D, or 3D drawings/assembly? Quote
Mike_Taylor Posted February 12, 2013 Posted February 12, 2013 Use the BLOCK command on your screws, it combines all drawing entities (lines, arcs, circles etc) into one entity called a block. You can then use the insert command to insert it as many times as required in your drawing. Quote
