Graeme Posted February 15, 2013 Posted February 15, 2013 A colleague has asked me over the phone about a command line problem he was with 2013LT in Classic Mode. His command line is reduced to about 20% of the full screen width. He has sent me a print screen and everything else looks ok. It is correctly parked in the space below the drawing area and above the status bar. It's left hand edge is corectly positioned but it is greatly reduced in width. The area to the right is the standard grey sort of colour as all the other blank areas. He tells me he can't drag the rh edge across the screen. We have tried dragging the whole cammand line onto the screen and then returning it to the parked position but to no effect. It was ok earlier in the day but obviously he has done something to break it. I can't dupicate it on mine and without direct access to his I can't try to sort it. Does anyone have a suggestion? Thanks Quote
ReMark Posted February 15, 2013 Posted February 15, 2013 He can close and reopen AutoCAD and see if that works. If it doesn't then he can try switching workplaces and see if that works. I have had it happen in the past. Quote
Graeme Posted February 15, 2013 Author Posted February 15, 2013 The blindingly obvious! That sorted it. Don't know why I didn't suggest that. Many thanks for your time and help. Quote
ReMark Posted February 15, 2013 Posted February 15, 2013 AutoCAD works in mysterious ways. You're entirely welcomed. Glad it worked. Quote
