I had this problem before, I just don't remember how it happened. I created a new lsp file from some code I pasted off of a website. Saved it in a notepad as a .lsp file and ran APPLOAD. After that things started going crazy. Now, each time I start AutoCAD I get s::startup-load. I am not sure if both of these things are even related but I need to just use autocad without this prompt crashing the application.
Thanks-
What happens when you remove this newly-saved-LISP-of-code-pasted-from-the-Al-Gore's-interwebs from your Startup Suite? :unsure:
  • 2 years later...
was this ever solved? I am having the same issue and cannot get it fixed. I have unloaded all of the lisp routines that I had added and it is still happening!
