Problem with Custom Command Buttons
parkerdepriest
 Share
I have two lisp routines I'm using to enforce some CAD standards in our office.
The first, STANDARD11x17, changes Dimensions, MLeaders, and MText to the appropriate styles. It prompts the user to "Include MText?" Yes or No.
The second, NORMAL, changes all layer plot style names to "Normal".
I've created toolbar buttons for these, using ^C^C (load "normal") normal
When I type in the commands at the command line, everything works fine, but when I try to use the NORMAL button after running STANDARD11x17, I get the following error:
Command:  STANDARD11X17
Include MText?(load "normal")
Can't reenter LISP.
Invalid option keyword.
Please help!
Shouldn't this already be defined in the default template to begin with?
ReMark,
The styles are defined in the template, but our template also has tabs for 8.5x11, 24x36, and 34x44. They each have corresponding commands.
 Share
