baker Posted February 27, 2013 Share Posted February 27, 2013 I did try a search and did not have much luck.. I am setting up SSM views and linking them to the callouts just fine. the normal Callout has the detail view # or letter above with the source sheet below. _A_ 12 "per-say" That is good and i have that working no issues. However.. here is what i am looking for. (its a 2 part issue) Part one In the plan views, I need the block to reference the source detail view and sheet as well as the sheet the callout is currently on. so... __A__ 02|12 Part two On the detail sheet; I need all the information as above, but i need to list or sync to every model sheet that call out is placed on. so... if i have the same detail view called out in 3 different model drawings, _______A__ 02, 03, 07|12 now, i am not concerned of the multiple locations going "outside" the bubble.. Any ideas would be great!! Quote Link to comment Share on other sites More sharing options...
