Hi,
I am drawing a 3d model of a flask.The body and spout are no problem its the handle im having problems with.I can do tabsurf for the middle of the handle but cant revolve around the bend in the handle.i know its not easy to explain.i think its the axis of revolution thats the problem as it revolves every way but the right one any advise would be great:(
Can you post an image so we can see what you are working with?
Would Extrude or Loft work?
flask with a handle? i would need to see an image as well. i would think loft or sweep would be the way to go. unless you can draw the cross section of the handle and revsurf about the center point for a few degrees.
a flask with a handle? thats new :)
is it a laboratory flask? Canister flask?
