spinecad Posted March 11, 2013 Posted March 11, 2013 is similar with the sketch view of Catia and Unigraphics? What this term called in the computer graphic? Quote
ReMark Posted March 11, 2013 Posted March 11, 2013 No, AutoCAD's plot preview is not at all equivalent to Catia's Sketcher. I think you would have to compare Catia to Inventor (also by AutoDesk). What "term" are you referring to? Quote
spinecad Posted March 12, 2013 Author Posted March 12, 2013 No, AutoCAD's plot preview is not at all equivalent to Catia's Sketcher. Yes indeed. No doubt. Below image is show you Unigraphics sketcher display looks like: http://s17.postimage.org/59is4yckf/spline.png Below image is show you Catia sketcher display looks like: http://postimage.org/image/ab2e9c28n/ Isn't all of them looks same as AUtoCAD's plot preview? What "term" are you referring to? You know Adobe Illustrator and Adobe Acrobat that usually used to make a .pdf file? If you zoom it, they will not blur like a pixel image. Quote
MSasu Posted March 12, 2013 Posted March 12, 2013 Don't know how Unigraphics and Catia were organized, but I suspect that is about a 3D modeling unit, respectively a 2D (sketch, shop drawing) one. So, to some extent, I believe that the right analogy to AutoCAD will be Model/Paper Space. The Print Preview feature is what you will find in many applications (not only CAD related) - just a feature that allow you to pre-visualize your work on paper. It is just static, not interactive. You know Adobe Illustrator and Adobe Acrobat that usually used to make a .pdf file?If you zoom it, they will not blur like a pixel image. For differences between raster and vector foramt, please check this article. Quote
ReMark Posted March 12, 2013 Posted March 12, 2013 Neither one of those images you linked to would be considered a Print Preview. You should reconsider the terminology you are using. "Print preview is a feature that allows a user to view what a printed version of the document would look like on the screen before printing a hard copy." Source: ComputerHope Quote
