anshulg
coordinate ; dimensions
anshulg
is there a function in autocad that can display the coordinates of a point...like when we use linear dimension lengthe of line is displayed..
Share this post
Link to post
ReMark
There are many custom lisp routines that will display the coordinates of a point.
Share this post
Link to post
Mike_Taylor
You could also make a block as well.
Share this post
Link to post
ReMark
If you are going to use a block then make sure you use fields to display the X/Y coordinates automatically.
Download the attached drawing. Invoke the INSERT command. Insert the block called "Test" into the drawing. Watch what happens.
The drawing was done in imperial units by the way. It has been saved in 2000 file format.
CoordinateBlockTest.dwg
Edited by ReMark
Share this post
Link to post
ReMark
anshulg: Did you arrive at a solution to your problem?
Share this post
Link to post
