Text in Blocks - Back to front
Hi, I am making up some furniture blocks with codes in. When I mirror those blocks the text goes back to front. I seem to remember that you can stop this from happening. Does anyone know this ? Thanks. Deborah Leach
Hi, thanks for taking the time to reply to my message. I have done this and it still goes back to front. I make my furniture, put the text in, the make it a block, then mirror it. What on earth do I do !?!?! Thanks.
Outside blocks this is controlled by MIRRTEXT system varialble; don't know if you can control this behavior for labels inside blocks.
No probs. I'll have to add the text outside the block :( Thanks anyway. Kind regards, Deborah
Text and Constant attributes within a block are mirrored regardless of the MIRRTEXT setting.
So set up your block with another type of attribute e.g. Preset, set MIRRTEXT to 0 and all should work as you want it to.
