rafaelrafa10 Posted March 13, 2013 Posted March 13, 2013 Hey. Can you tell me how can I make a section plane and the respective projection in autocad mechanical? The following link will explain you what i want to do. Ty http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%202010%20User%20Documentation/images/PTDCPM/Gator-All/English/tooltip_section_plane.gif Quote
SLW210 Posted March 14, 2013 Posted March 14, 2013 Pretty good explanation in AutoCAD Help file. You might also check the "Similar Threads" below. There are some tutorials on YouTube just search "autocad section plane tutorial". Quote
ReMark Posted March 14, 2013 Posted March 14, 2013 I know of a paper presented at AutoDesk University that explains the procedure but it was written for generic AutoCAD. Not sure if the procedure would be any different in Mech. Quote
SLW210 Posted March 14, 2013 Posted March 14, 2013 AFAIK, Sectionplane is not available in Mechanical, the OP will need to run vanilla AutoCAD, so it would be the same procedure. Quote
