kililio Posted March 16, 2013 Posted March 16, 2013 Hi When I select "area" I choose area plan and purple lines surrounding my walls and divide each room, I created them earlier I can see the area of my rooms in the properties panel, but how to tag that area as annotation? I when I go to "tag area" I can't select any room, nothing happens What to do? Thx Quote
Moker Posted March 16, 2013 Posted March 16, 2013 The only real way I know for sure is to go to, Architecture ribbon-Room&Area-Room. Thats manually adding a tag to each room. That should turn each room to an element. You may be able to do it in Annotate-Room tag if the Room boundary is on. I'm not sure Quote
nocturne00 Posted March 20, 2013 Posted March 20, 2013 Hi When I select "area" I choose area plan and purple lines surrounding my walls and divide each room, I created them earlier I can see the area of my rooms in the properties panel, but how to tag that area as annotation? I when I go to "tag area" I can't select any room, nothing happens What to do? Thx Just to asses first your situation. -You are working in Area plans [NOT FLOOR PLANS] and you've finished placing area boundary lines. -after the area boundary lines, you place the "Areas" (Not rooms) -then you tried use "Area Tag" immediately after, wherein you are unable to tag the areas? *** Just to clarify coz in your last sentence you've mentioned not being able select the "Room", w/c is quite differenct from an area Quote
kililio Posted March 20, 2013 Author Posted March 20, 2013 Hi i solved that issue by going in edit type option I duplicate the tag and named it differently. There was a "area" button to check I unchecked "volume" Voila Thx for your answer Quote
