I would go ahead and correct the model rather than try to work with this model.
What I meant is that if it were my work I would do this. I did not mean that I am going to do it for you. You already stated that you could fix it - so that is what you should do.
You do not need to split the model.
I would Subtract the model from a block and then split the block to create the core/cavity.
Just for fun I might do the work later today - but my time is limited.
(If I give it a try I won't be using an antiquated software like AutoCAD - I will use a modern program like Autodesk Inventor. I will use your scanned model only for reference in re-modeling the part correctly.)
  • Replies 22
  • dmmahesh
    13
  • JD Mather
    9
  • f700es
    1
Posted Images
Dear Mr.J.D.Mather,
thanks for your so far guidance and support. I've finished,
Just I subtracted the model from block and sliced into core and cavity inserts. Further I can easily do. Thanks a lot.
Dear Mr.J.D.Mather,
I did with your support, hence I tried to start from the beginning, Just I converted that *.igs file, which was provided after done the 3D scan of the real part, into *.sat using Pro-E. And with ACAD-2007 I planed that *.sat file.. and scared.. yes the dwg is completely broken and scattered.. how to convert any *.igs file into *.sat to work further with ACAD-2007. Pls guide..
FYI.. find the *.sat file converted using Pro-e
drme_3dscan_shoehorn_Trial_260313.zip
