woodman78 Posted March 21, 2013 Share Posted March 21, 2013 Hi, When I try to use this code: (defun c:UnDynamic ( / _get_item _right _make_key _dynamic->static_block _get_locked _get_dynamic_inserts _main ) (defun _get_item ( collection key / item ) (vl-catch-all-apply '(lambda ( ) (setq item (vla-item collection key))) ) item ) (defun _right ( str n / len ) (if (< n (setq len (strlen str))) (substr str (1+ (- len n))) str ) ) (defun _make_key ( collection prefix len / key ) ( (lambda ( i pad ) (while (_get_item collection (setq key (strcat prefix (_right (strcat pad (itoa (setq i (1+ i)))) len ) ) ) ) ) key ) 0 ( (lambda ( pad ) (while (< (strlen pad) len) (setq pad (strcat "0" pad)) ) pad ) "" ) ) ) (defun _dynamic->static_block ( blocks insert len ) (vla-ConvertToStaticBlock insert (_make_key blocks "STATIC_" len) ) ) (defun _get_locked ( layers / locked ) (vlax-for layer layers (if (eq :vlax-true (vla-get-lock layer)) (setq locked (cons layer locked)) ) ) locked ) (defun _get_dynamic_inserts ( blocks / inserts ) (vlax-for block blocks (vlax-for object block (if (eq "AcDbBlockReference" (vla-get-objectname object)) (if (eq :vlax-true (vla-get-isdynamicblock object)) (setq inserts (cons object inserts)) ) ) ) ) inserts ) (defun _main ( document / blocks inserts locked len ) (if (setq inserts (_get_dynamic_inserts (setq blocks (vla-get-blocks document)) ) ) (progn (foreach layer (setq locked (_get_locked (vla-get-layers document))) (vla-put-lock layer :vlax-false) ) (setq len (strlen (itoa (length inserts)))) (foreach insert inserts (_dynamic->static_block blocks insert len) ) (foreach layer locked (vla-put-lock layer :vlax-true) ) ) ) (princ) ) (_main (vla-get-activedocument (vlax-get-acad-object))) ) that comes from here: http://www.theswamp.org/index.php?topic=32681.msg382548#msg382548 I get the following message: ; error: Automation Error. Duplicate key Does anyone have any ideas? Quote Link to comment Share on other sites More sharing options...
David Bethel Posted March 21, 2013 Share Posted March 21, 2013 I would think that if you SAVEAS any release prior to 2011, you would 'un' dynamic blocks. ?????? -David Quote Link to comment Share on other sites More sharing options...
