suriwaits Posted March 31, 2013 Share Posted March 31, 2013 Hi, I would like to have a lisp for calculating flow of Irrigation sprinklers in a click. There are different blocks in a drawing. I would like to assign 0.23 to block1 and 0.12 to block 2 and 0.06 to block3. The lisp required is calculate flow by Number of Block1 x 0.23 + Nr. of Block2 x 0.12 + Nr of block 3 x 0.06, when finished selecting blocks. If someone could write this in Autolisp, I would appreciate it. Thanks, and let me know if the explanation was not clear Quote Link to comment Share on other sites More sharing options...
Tharwat Posted March 31, 2013 Share Posted March 31, 2013 Welcome to Cadtutor Does it mean that you have block ( not attributed blocks ) and you want to calculate the values in the selected blocks ? If not , please be more specific to your aim of the routine . Tharwat Quote Link to comment Share on other sites More sharing options...
suriwaits Posted March 31, 2013 Author Share Posted March 31, 2013 Thanks for your prompt response. I have block without attributes. I have similar thread in the following link http://www.cadtutor.net/forum/showthread.php?54111-Data-Extraction&highlight=irrigation I am looking for the same for the blocks without attributes. Thanks again, Suriwaits. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted March 31, 2013 Share Posted March 31, 2013 Do you want to have the values in a text or by an alert message ? Quote Link to comment Share on other sites More sharing options...
suriwaits Posted March 31, 2013 Author Share Posted March 31, 2013 Alert message would be great.. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted March 31, 2013 Share Posted March 31, 2013 Try this draft at the moment ... (defun c:Test (/ *error* IfBlockhasSingleTextObject _sum j ss i sn l) ;;--- Tharwat 31. March, 2013 ---;; (defun *error* (msg) (princ "\n*Cancelled by user or by coincidence ,Nothings more*" ) ) (defun IfBlockhasSingleTextObject (e / i) (setq i 0) (setq e (tblobjname "BLOCK" (cdr (assoc 2 (entget e))))) (while (and (setq e (entnext e)) (not (eq (cdr (assoc 0 (entget e))) "SEQEND")) ) (if (wcmatch (cdr (assoc 0 (entget e))) "*TEXT") (setq i (1+ i)) ) ) i ) (defun _sum (en / sm) (setq sm 0.) (setq en (tblobjname "BLOCK" (cdr (assoc 2 (entget en))))) (while (and (setq en (entnext en)) (not (eq (cdr (assoc 0 (entget en))) "SEQEND")) ) (if (and (wcmatch (cdr (assoc 0 (entget en))) "*TEXT") (numberp (read (cdr (assoc 1 (entget en))))) ) (setq sm (+ (read (cdr (assoc 1 (entget en)))) sm)) ) ) sm ) (if (setq j 0. ss (ssget "_:L" '((0 . "INSERT"))) ) (repeat (setq i (sslength ss)) (setq sn (ssname ss (setq i (1- i)))) (if (eq (IfBlockhasSingleTextObject sn) 1) (setq j (+ (_sum sn) j)) (setq l (cons sn l)) ) ) ) (if l (alert (strcat "You have < " (itoa (length l)) " > Blocks doesn't have or have more than one Text entity " ) ) ) (if (> j 0) (alert (strcat "Total Values : " (rtos j 2 4))) ) (princ "\nWritten by Tharwat Al Shoufi") (princ) ) Quote Link to comment Share on other sites More sharing options...
suriwaits Posted March 31, 2013 Author Share Posted March 31, 2013 Dear Mr.Tharwat It seems nice lisp. Thanks I will try your lisp in the morning when reaching my office. By seeing your lisp and also my insufficient input given to you, this won't work as i would like to, Since My blocks don't have any text value or attribute in it say for example, for the block with block name is BLK1, it should have value of 0.23 similarly for BLk2 - 0.12 and for BLK3 - 0.06 (the value not necessarily to be shown in the DWG, it should take this value and multiply by number of corresponding block and sum it with other blocks x value and display as Flow is "value of the sum" I will use your program posted here, if it is not possible how i want.. Suriwaits Quote Link to comment Share on other sites More sharing options...
Tharwat Posted March 31, 2013 Share Posted March 31, 2013 If you can upload a sample drawing , that would be much more clearer to know the goal of the code . Quote Link to comment Share on other sites More sharing options...
suriwaits Posted March 31, 2013 Author Share Posted March 31, 2013 Dear Mr.Tharwat, Your program works flawlessly when the block has text of desired value. In the attached drawing, 3 different blocks are there and following is the qty 15 Nr of 180DEG 9 Nr of 360DEG 2 Nr of 90DEG now i want program to calculate 15x0.12 + 9x0.23 + 2x0.06 0.12, 0.23 & 0.06 are respective flow of 180deg, 360 deg and 90 deg irrigation spray nozzles. Sprayer1 - Copy.dwg Quote Link to comment Share on other sites More sharing options...
Tharwat Posted March 31, 2013 Share Posted March 31, 2013 If I got you well . (defun c:Test (/ *error* j ss i e) ;;--- Tharwat 31. March, 2013 ---;; (defun *error* (msg) (princ "\n*Cancelled by user or by coincidence ,Nothings more*" ) ) (if (setq j 0. ss (ssget "_:L" '((0 . "INSERT") (2 . "180DEG,360DEG,90DEG"))) ) (repeat (setq i (sslength ss)) (setq e (entget (ssname ss (setq i (1- i))))) (cond ((eq (cdr (assoc 2 e)) "90DEG") (setq j (+ 0.12 j)) ) ((eq (cdr (assoc 2 e)) "180DEG") (setq j (+ 1.8 j)) ) (t (eq (cdr (assoc 2 e)) "360DEG") (setq j (+ 2.07 j)) ) ) ) ) (if (> j 0) (alert (strcat "Total Values : " (rtos j 2 4))) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
suriwaits Posted March 31, 2013 Author Share Posted March 31, 2013 (edited) Fabulous stuff. Thank you for time you have spent on my request and i appreciate it. works very well i have changed the value as i wanted it (defun c:Test (/ *error* j ss i e) ;;--- Tharwat 31. March, 2013 ---;; (defun *error* (msg) (princ "\n*Cancelled by user or by coincidence ,Nothings more*" ) ) (if (setq j 0. ss (ssget "_:L" '((0 . "INSERT") (2 . "180DEG,360DEG,90DEG"))) ) (repeat (setq i (sslength ss)) (setq e (entget (ssname ss (setq i (1- i))))) (cond ((eq (cdr (assoc 2 e)) "90DEG") (setq j (+ 0.06 j)) ) ((eq (cdr (assoc 2 e)) "180DEG") (setq j (+ 0.12 j)) ) (t (eq (cdr (assoc 2 e)) "360DEG") (setq j (+ 0.23 j)) ) ) ) ) (if (> j 0) (alert (strcat "Total Values : " (rtos j 2 4))) ) (princ) ) Edited April 3, 2013 by SLW210 Added Code Tags!! Quote Link to comment Share on other sites More sharing options...
Tharwat Posted March 31, 2013 Share Posted March 31, 2013 Fabulous stuff.Thank you for time you have on my request and i appreciate it. works very well Excellent , Very happy to hear that . Quote Link to comment Share on other sites More sharing options...
suriwaits Posted April 3, 2013 Author Share Posted April 3, 2013 Hi, I am in need of a lisp to do the following for placing placing block on a pline boundary: Step1 1. Command to ask to pick a pline/line (Command line or alert) 2.Display List length of the objects picked (Alert msg). Ask the user to input " Enter Spacing of head" (input should be either on of these numbers) 3.divide the displayed value by user input value 4.Display the divide value as "No of Possible heads are . (Alert msg ) 5.Ask the user to input "Desired no of heads are (this will be rounded value of the above). (Alert msg ) 6.Calculate Length divided by Desired no heads, is within +-0.25 from the input value (inputs are 1.25,2.25,2.75,3.25,4.25) then proceed to step 7 if it is not within +-0.25 from the input value, ask the user to " Enter to different value or ESC to cancel the operation If different value is entered, repeat step 6 7. Use the autocad divide command, take the input as the number of segment from step 6 once it passed the criteria. 8. Use Block option 9. if the user input is 1.25 then input the block name as 5-180 2.25 then input the block name as 8-180 2.75 then input the block name as 10-180 3.25 then input the block name as 12-180 4.25 then input the block name as 15-180 10. End Thanks in advance Suriwaits. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 3, 2013 Share Posted April 3, 2013 Please read the CODE POSTING GUIDELINES and in the future place your Code in Code Tags. I fixed it for you this time. Quote Link to comment Share on other sites More sharing options...
