It has been quite a while since I wrote anything in lisp, but I am attempting to create a simple program to read some input from a dialog box and write that to a text file. Of course I will have more to add to it eventually but at this point I'm just trying to get it to write to the text file correctly. This is what i have, but I am getting the error "bad argument type: streamp nil" and I'm really not sure what is causing it. I'm stumped, if anyone could point me in the right direction I would really appreciate it.
;EDI2.lsp
(defun EDI2 ()
(defun *error* (msg)
 (reset)
(defun reset ()
 (unload_dialog dcl_id)
(setq dcl_id (load_dialog "edi.dcl"))
(defun write_header ()
 (setq fname (open "C:\edi\test.txt"))
 (setq fdesc (open fname "w"))
 (write-line "po" fdesc)
 (write-line "oc" fdesc)
 (write-line "jobname" fdesc)
 (write-line "workorder" fdesc)
 (close fname)
(defun end_setup ()
 (setq po (get_tile "po"))
 (setq oc (get_tile "oc"))
 (setq jobname (get_tile "jobname"))
 (setq workorder (get_tile "workorder"))
 (done_dialog)
 (write_header)
 (if (not (new_dialog "setup" dcl_id))
  (exit))
 (action_tile "accept" "(end_setup)")
 (action_tile "cancel" "(exit)")
 (start_dialog)
 (reset)
The problems are in your WRITE_HEADER function: you called the OPEN function twice, first without a mode argument; the path should be written with double backslash; also the CLOSE function have a wrong argument.
 (setq fname [s][color=red](open[/color][/s] "C:\[color=red]\[/color]edi\[color=red]\[/color]test.txt"[s][color=red])[/color][/s])
 (close [color=red]fdesc[/color])
On Cancel event, I would suggest you to terminate the dialog instead of forcing exit:
(action_tile "cancel" "[color=red](done_dialog 0)[/color]")
By the way, since you redefined the error function, a good programming practice is to retain its original state and restore it when your routine exit.
Thanks! I made the changes you suggested but unfortunately I am getting a different error now. This time it is "bad argument type: streamp nil".
;EDI2.lsp
(defun EDI2 ()
 (reset)
(defun reset ()
 (setq fname "C:\\edi\\test.txt")
 (close fdesc)
(defun end_setup ()
 (done_dialog)
 (write_header)
  (exit))
 (action_tile "cancel" "(done_dialog 0)")
 (start_dialog)
 (reset)
Any ideas? :?
Is the required folder named EDI available on drive C:? Do you have write privileges into that folder?
That was it! The computer i was testing it on did not have an EDI folder created. Thank you very much, i think I can handle the rest of the program from here.
Good to heat that you got it sorted.
For safety, may want to add something like this to your code:
(setq myPath "C:\\Edi\\")
(if (not (vl-file-directory-p myPath))
(vl-mkdir myPath)
