how to delete page setup name one at a time
hi, i working for hundreds of drawings, my goal is to delete all PAGE SETUP NAME loaded on each drawings using lisp routine, instead of opening one-by-one & manuallly delete all page setup name manually....anybody who has the lisp routine that can automate this process? thanks in advance
regards,
the courage dog:(
  • 3 weeks later...
how do you manually delete a page setup?
Go to "plot", then where it says "page setup name" click "add", select your page setup and click "delete"
I have VBA to do it, do you want that?
Public Sub DelPConfig()
     Dim objPlotConfigs As AcadPlotConfigurations
     Dim objPlotConfig As AcadPlotConfiguration
     Set objPlotConfigs = ThisDrawing.PlotConfigurations
     For Each objPlotConfig In objPlotConfigs
           objPlotConfig.Delete
     Next
End Sub
sir,
last 4 months im using autocad 2005, now im using 2007, how can i attatch landscape in autocad 2007 when the lsnew, lslib, and lsedit commands are removed in 2007
sir, how can i create landscape command lsnew, in autocad2007 when the command is removed
  • 5 years later...
     Next
End Sub
Thanks CmdrDuh
Nothing is as easy as it seems.
...back to the search function...
I wonder why Autodesk doesn't just allow it to be part of the Purge command.
