samifox Posted April 11, 2013 Posted April 11, 2013 hi i want to create a rectangle, lets say 40x40, and dublicat it 100 times by 20 units inteval, than mirror all the 100 instance verticaly , than move all 200 entities 200 units down (you an think of whatever basic action you want, i just want to see this code and trace its sources in the help reference so i can understand how to use the help) please help (defun dm() (vl-load-com) (setq acadObject (vlax-get-acad-object)) (setq acadDocument (vla-get-ActiveDocument acadObject)) (setq mSpace (vla-get-ModelSpace acadDocument)) (setq mycircle (vla-addCircle mSpace (vlax-3d-point '(3.0 3.0 0.0)) 2.0)) (setq cop2 (vla-copy mycircle)) (setq util (vla-get-utility (vla-get-activedocument (vlax-get-acad-object)))) ;move the object (vla-move mycircle BP PT2) ) Thanks Shay Quote
BIGAL Posted April 12, 2013 Posted April 12, 2013 Rectang or circle like code a 100 times use "entlast" then "Array" dont copy thats what Array does. If you draw on 1 layer particuarly a temporary one then you can do "boundingbox" search here, and then say "mirror" change final resulting objects (boundingbox) to correct layer this way your temp layer has nothing on it. Not sure on the vla-addarray else (command "_Array" follow prompts) Quote
irneb Posted April 12, 2013 Posted April 12, 2013 Well the OP asked for the VL way of doing it: (vl-load-com) (setq *Application* (vlax-get-acad-object) *ActiveDocument* (vla-get-ActiveDocument *Application*)) ;; Draw a rectangle (defun ax_DrawRect (pt1 pt2 / Space obj) (setq Space (vlax-get *ActiveDocument* (if (< (getvar "CVport") 2) ;Check which space is active 'PaperSpace 'ModelSpace)) pt1 (mapcar '+ pt1 '(0. 0.)) ;Ensure only 2D points pt2 (mapcar '+ pt2 '(0. 0.)) ;dito ;; Create the rectangle obj (vlax-invoke Space 'AddLightWeightPolyline (append pt1 (list (car pt2) (cadr pt1)) pt2 (list (car pt1) (cadr pt2))))) (vla-put-Closed obj :vlax-true) obj) ;; Copy an object (defun ax_Copy (obj vector / new) (if (not (vl-catch-all-error-p (setq new (vl-catch-all-apply 'vla-Copy (list obj))))) (progn (vlax-invoke new 'Move '(0. 0. 0.) vector) new))) ;; Mirror an object (defun ax_Mirror (obj pt1 pt2 / new) (if (not (vl-catch-all-error-p (setq new (vl-catch-all-apply 'vla-Mirror (list obj (vlax-3d-point pt1) (vlax-3d-point pt2)))))) new)) And then to use those functions: _$ (setq obj (ax_DrawRect '(0. 0.) '(40. 40.))) #<VLA-OBJECT IAcadLWPolyline 000000002fc03dd8> _$ (setq obj1 (ax_Copy obj '(60. 0. 0.))) #<VLA-OBJECT IAcadLWPolyline 000000002fc04258> _$ (setq obj2 (ax_Mirror obj '(0. 0. 0.) '(60. 0. 0.))) #<VLA-OBJECT IAcadLWPolyline 000000002fc02c98> Quote
