beha Posted April 11, 2013 Posted April 11, 2013 Dear forum I'm fairly new in autoCAD, and still haven't gotten to completely understand - and live with all the small oddities of the software. The last couple of times I've been using it I've been experiencing the same problem occurring. Whenever I've done some drawings, in 1:1 and I want to get it from the viewport and out of the software the scales won't fit. For instance I'm right now having a part of a drawing being 20cm in 1:1, but whenever I set the viewport scale to 1:20 it makes this 20cm long element 15 cm'ish long. All units are set to millimeter. I hope that somebody are able to help me. _Beha Quote
SLW210 Posted April 11, 2013 Posted April 11, 2013 Can you post the drawing (saved to 2010 or older)? Quote
beha Posted April 11, 2013 Author Posted April 11, 2013 http://www.megafileupload.com/en/file/410414/example-dwg.html I've tried to upload a small example that should explain my problem, I hope that the upload works. Quote
SLW210 Posted April 11, 2013 Posted April 11, 2013 You'll need to upload it straight to CADTutor for me to look at it, Select "Go Advanced" at lower right of reply box, then select "Manage Attachments". Quote
ReMark Posted April 11, 2013 Posted April 11, 2013 First of all your drawing was done using a template normally used for drawings done in an imperial scale (decimal inches) not a metric scale. In the future use the acadiso.dwt template whenever you start a new drawing and not the default template (acad.dwt). Quote
rkent Posted April 11, 2013 Posted April 11, 2013 How did you measure in PS?, it seems to measure correctly here. Quote
