meric_u2003 Posted April 16, 2013 Posted April 16, 2013 Hi Mmebers, I have some ground elevations in my drawing i want to substrat 0.3 or 0.5 from tht value and also after changing i need to change the colour of the value same time.Is there any lisp for that?? Any one can help me.. Â sorry for my bad Englsih Quote
Lee Mac Posted April 16, 2013 Posted April 16, 2013 Try this program: Â http://www.cadtutor.net/forum/showthread.php?45679&p=509051&viewfull=1#post509051 Quote
Tharwat Posted April 16, 2013 Posted April 16, 2013 This ... ? Â (vl-load-com) (defun c:Test (/ kw no s) ;;---- Tharwat 16. April. 2013 ----;; (if (and (progn (initget "Add Subtract") (setq kw (getkword "\n Choose one [Add,Subtract] :")) ) (setq no (getdist "\n Specify the value :")) (progn (princ "\n Select Texts ") (ssget "_:L" '((0 . "*TEXT"))) ) ) (progn (vlax-for x (setq s (vla-get-ActiveSelectionSet (vla-get-ActiveDocument (vlax-get-acad-object)) ) ) (if (numberp (read (vla-get-textstring x))) (if (eq kw "Add") (vla-put-textstring x (strcat (rtos (+ (read (vla-get-textstring x)) no) 2 2)) ) (vla-put-textstring x (strcat (rtos (- (read (vla-get-textstring x)) no) 2 2)) ) ) ) ) (vla-delete s) ) ) (princ) ) Quote
meric_u2003 Posted April 16, 2013 Author Posted April 16, 2013 I mean like this from those values i want to substract or add... there is a lot of values to be done  like 96.04-0.03=96.01 likewise  like while am clicking on tht number it automatically change Quote
Tharwat Posted April 16, 2013 Posted April 16, 2013 Try this ... Â (vl-load-com) (defun c:Test (/ kw no s st v) ;;---- Tharwat 16. April. 2013 ----;; (if (and (progn (initget "Add Subtract") (setq kw (getkword "\n Choose one [Add,Subtract] :")) ) (setq no (getdist "\n Specify the value :")) (progn (princ "\n Select Texts ") (ssget "_:L" '((0 . "*TEXT"))) ) ) (progn (vlax-for x (setq s (vla-get-ActiveSelectionSet (vla-get-ActiveDocument (vlax-get-acad-object)) ) ) (if (numberp (read (vla-get-textstring x))) (progn (setq st (vla-get-textstring x) v (rtos no 2 2) ) (cond ((eq kw "Add") (vla-put-textstring x (strcat st "+" v "=" (rtos (+ (read st) (read v)) 2 2)) ) ) (t (vla-put-textstring x (strcat st "-" v "=" (rtos (- (read st) (read v)) 2 2)) ) ) ) ) ) ) (vla-delete s) ) ) (princ) ) Quote
BIGAL Posted April 17, 2013 Posted April 17, 2013 Tharwat you dont need add or subtract as a option a negative value implies when added to a number to subtract anyway. Hence the wording enter height adjustment.  Just realised a simple problem in the code posted including mine need a extra question decimal places required set it say at a default value so can do a enter for default. 0 1 2 3 .  Also does the code need to be able to change the FL=90.36 to FL=90.06 this can be done quite easily as a variation on the code's posted thanks to Lee's parse number lisp.  Heres a double version pick pick etc or multi pick an oldy quite a few years ago  ; Adds a fixed amount to a number ;(PRINC "\nTO USE JUST TYPE A2L or A2LM for multiple ") (Alert "TO USE JUST TYPE A2L or A2LM for multiple ") ;(setvar "cmdecho" 1) (setq olddimzin (getvar "Dimzin")) (setvar "dimzin" 0) (DEFUN c:A2L () (setq v2 (getreal "\nEnter ht adjustment ")) (setq test 1) (while (= test 1) (setq en1 (car (entsel "\nSelect text number:" ))) (if (/= en1 nil) (progn (setq el1 (entget en1)) (setq v1 (atof (cdr (assoc 1 el1)))) (setq a (+ v1 v2)) (setq b (rtos a 2 3)) (setq el (subst (cons 1 b) (assoc 1 el1) el1)) (entmod el) ; (entupd en1) );progn (princ "\nplease pick again"); else );if ); while true (setq el nil) (setq en nil) (setq a nil) (setq v1 nil) (setvar "cmdecho" 1) (setvar "dimzin" olddimzin) (princ) ); END a2l DEFUN (defun c:A2LM () (setq v2 (getreal "\nEnter ht adjustment ")) (setq ss (ssget (list (cons 0 "Text")))) (setq len (sslength ss)) (setq x 0) (repeat len (setq en1 (ssname ss x)) (setq el1 (entget en1)) (setq v1 (atof (cdr (assoc 1 el1)))) (setq a (+ v1 v2)) (setq b (rtos a 2 3)) (setq el (subst (cons 1 b) (assoc 1 el1) el1)) (entmod el) (setq x (+ x 1)) ); repeat (setq el nil ss nil) (setq en nil) (setq a nil) (setq v1 nil) (setvar "dimzin" olddimzin) (setvar "cmdecho" 1) (princ) ); END a2lm DEFUN 1 Quote
meric_u2003 Posted April 17, 2013 Author Posted April 17, 2013 thnks guys it helps me a lot exp. Mr.Bigal's lisp  thnks for ur effort guys Quote
Ish Posted December 21, 2021 Posted December 21, 2021 (edited) On 4/17/2013 at 6:44 AM, BIGAL said: Tharwat you dont need add or subtract as a option a negative value implies when added to a number to subtract anyway. Hence the wording enter height adjustment.  Just realised a simple problem in the code posted including mine need a extra question decimal places required set it say at a default value so can do a enter for default. 0 1 2 3 .  Also does the code need to be able to change the FL=90.36 to FL=90.06 this can be done quite easily as a variation on the code's posted thanks to Lee's parse number lisp.  Heres a double version pick pick etc or multi pick an oldy quite a few years ago   ; Adds a fixed amount to a number ;(PRINC "\nTO USE JUST TYPE A2L or A2LM for multiple ") (Alert "TO USE JUST TYPE A2L or A2LM for multiple ") ;(setvar "cmdecho" 1) (setq olddimzin (getvar "Dimzin")) (setvar "dimzin" 0) (DEFUN c:A2L () (setq v2 (getreal "\nEnter ht adjustment ")) (setq test 1) (while (= test 1) (setq en1 (car (entsel "\nSelect text number:" ))) (if (/= en1 nil) (progn (setq el1 (entget en1)) (setq v1 (atof (cdr (assoc 1 el1)))) (setq a (+ v1 v2)) (setq b (rtos a 2 3)) (setq el (subst (cons 1 b) (assoc 1 el1) el1)) (entmod el) ; (entupd en1) );progn (princ "\nplease pick again"); else );if ); while true (setq el nil) (setq en nil) (setq a nil) (setq v1 nil) (setvar "cmdecho" 1) (setvar "dimzin" olddimzin) (princ) ); END a2l DEFUN (defun c:A2LM () (setq v2 (getreal "\nEnter ht adjustment ")) (setq ss (ssget (list (cons 0 "Text")))) (setq len (sslength ss)) (setq x 0) (repeat len (setq en1 (ssname ss x)) (setq el1 (entget en1)) (setq v1 (atof (cdr (assoc 1 el1)))) (setq a (+ v1 v2)) (setq b (rtos a 2 3)) (setq el (subst (cons 1 b) (assoc 1 el1) el1)) (entmod el) (setq x (+ x 1)) ); repeat (setq el nil ss nil) (setq en nil) (setq a nil) (setq v1 nil) (setvar "dimzin" olddimzin) (setvar "cmdecho" 1) (princ) ); END a2lm DEFUN   @BIGAL Edited December 22, 2021 by Ish H Quote
Steven P Posted December 21, 2021 Posted December 21, 2021 Time to start learning some code, this is quite easy so a good start for you.. and google is also your friend.  So in BigAls example he has a couple of lines asking for ht adjustment, something like this "(setq v2 (getreal "\nEnter ht adjustment "))" and I reckon that they are the lines to look at changing.  An internet search might give you this to try: (setq v2 (vla-get-TextString (vlax-ename->vla-object (car (entsel)))))  Note from experience that this line doesn't have any text to tell the user what it is expecting, you might try something like (princ "zzzz") just before this line to tell the user what to do, and you might get an error that your new V2 is seen as a text string rather than a number, again you can look at Google to see what it says to fix that... it is all out there... (for string to integer maybe try (type v2) to show what it is and then a search if that result is STR what to do... (if (= 'STR (type v2))(princ "String")(princ "Number")).. and then just change the 2 princ commands to what you need it to do).  There I reckon that should be enough to give you some thinking but also a solution  Much nicer way of asking and you get better help if you can have a go and then ask "I have tried these changes but it isn't quite working" 1 Quote
