Hey guys,
I am wondering if it is possible to create some sort of block which will detect the angle it has been rotated to and present this angle as a text? For eg. to calculate the superelevation and present it as a multileader with 3.00% above it.
Cheers!
We do this as a lable using a lisp it asks first horizontal scale & Vertical, number of decimals then pick line writes answer above line very simple line lable lisp. You may be able to do this using fields using the block angle, only problem is you may need more than 1 block to allow for different scales.
An alternative will be to use a field - please check the FIELD command.
