chance Posted October 20, 2006 Share Posted October 20, 2006 ok this started popping up out of the blue....happens while I am closing....any takers.... Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted October 21, 2006 Share Posted October 21, 2006 I used to see this a lot when we used LDT 3 (2002 based). I believe it's a common thing with this version, maybe just the verticals... It isn't hurting anything, right? It just shows up when you close? Quote Link to comment Share on other sites More sharing options...
KimbleC Posted August 7, 2009 Share Posted August 7, 2009 I have the following while using the publish command to print pdf files. Visual C++ Runtime Error R6025. Has anyone seen a suitable answer/reason for this error. AutoCAD locks up so you have to crash out loosing some of your work because you have forgotten to save. Quote Link to comment Share on other sites More sharing options...
