NEXTMARCUS Posted April 18, 2013 Share Posted April 18, 2013 Hi everyone ! Do Anyone know A way to plot several .dwg drawings in a3 format to pdf files and then gather these files in a pdf file? i made this routine but it plots just one page to pdf and i need to put the path of the file: zoom all -PLOT Y MODEL dwg to pdf.pc3 ISO A3 (420.00 x 297.00 MM) MILLIMETERS L NO extents fit Center Y monochrome.ctb Y As %file% N Y SAVEAS 2007 Y Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 19, 2013 Share Posted April 19, 2013 There is lots of discussion about this if you search PDF & Plotting, There is a lot of info about using different pdf programs, I have posted a version which will let you plot out of as many dwg's as you like but it plots individual pdfs, I never really found an answer to this, but does put them in the desired location. I have posted 2 versions here one for multiple title blocks in modelspace and the other for multiple layouts. There is also plot by view's. If you set up "publish" in each drawing then it can be done. Quote Link to comment Share on other sites More sharing options...
