amingame7 Posted April 21, 2013 Share Posted April 21, 2013 Hi guys I face new problem in using solid hatch command ,when I choose poly lines and use hatch some unwanted lines appears inside hatch area which make my shape separate from others part be meant be unify. I am amateur in using auto cad .BTW , my scale is about 5 micron meter and when I export the drawing int pdf all straight lines become curvy .I upload the image which describe itself my problem http://postimg.org/image/goenlo4rn/ http://postimg.org/image/4tr3x9p51/Please tell me how can i solve the problem If i should change some setting or what else in detailthank u! Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 22, 2013 Share Posted April 22, 2013 Is it possible to post your image directly to CADTutor? At lower right of Reply box select "Go Advanced" then select "Manage Attachments". Quote Link to comment Share on other sites More sharing options...
