Mike Kramer Posted April 22, 2013 Share Posted April 22, 2013 just in the lst day when trying to creat a plot file it goes through the process like it's working fine but after creating the plot file ist's empty 0 memory. It shows the plot preview correctly but after sent to plot the plt file is 0 memory and has nothing to plot. This just started never happened before. Using 2000 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 23, 2013 Share Posted April 23, 2013 Why not go to pdf ? or do you need a older HPGL plt, try -plot and answer the question near end is plot to file. You may need to go into plotter set up to make plot to file is set right you maybe outputting to a file you dont know about. Quote Link to comment Share on other sites More sharing options...
