Hi Guys,
Trying to remove multiple hatch grips. My problem is as simple as that!
Since 2011 brought in the pop-up option, single grips can be removed with this method.
But when I want to delete a larger number of grips at once, I can't achieve the required result.
Process is as follows:
1. Select Hatch itself
2. Holding SHIFT, select multiple grips (which turn from blue to red)
3. Then 1 left click on a grip, and scrolling through the options using CTRL key until I arrive at 'REMOVE'. Then another left click and nothing happens!
Any assistance would help with avoidance of head being done in!
Cheers, Clarky. :)
Link to post
I've since discovered that by moving the grip in question outside the existing hatch area perimeter (anywhere I fancy) it is then removable. But to solve my thread post problem, I'd have to move all the troublesome grips then select them all to delete. Too cumbersome.
Link to post
