Is there a way to assign the middle button of an optical mouse such that the object selection toolbar appear right away instead of clicking the right button while holding the shift key? This used to work for releases 10,11, 12 and 14 but just can't configure it for AutoCAD 2008. Thank you.
Are you saying that you want to press the middle mouse button and the snap points shortcut menu appears?
Tools, customisation would be a good place to start and also checking out the options menus might help.
I'll have a look later and if no-one else has solved your problem I'll do my best.
MBUTTONPAN works ! Thank you Mr. Eldon and Mr. Wannabe. This is a very useful shortcut.
