SMP Posted April 29, 2013 Share Posted April 29, 2013 Hello Forum. I am having an issue plotting some PDF's? I am using Adobe Pro 10 I believe. It just simply will not print to scale. When I use the measuring tool within adobe it says it is the correct scale? In the print menu, I have it checked off to print to the actual size, yet it is still shrinking it slightly. I have tried this on every one of our printers and I get the same results. I am thinking this is a setting in Adobe I am over looking. When I print from Brava reader I do not have this issue, except it looks like a crappy rasterized version? Any thoughts? Quote Link to comment Share on other sites More sharing options...
Guest AARi Posted May 8, 2013 Share Posted May 8, 2013 Autocad has a command saveas PDF, quite nice [you can display the layers separately]... [try to obtain the original ones] another free print driver is PDF995 search for it... [install [couple of files] it and you will got it in your printer windows] sometimes pdf plot-drivers not work eff. Quote Link to comment Share on other sites More sharing options...
