Gjay001 Posted May 2, 2013 Share Posted May 2, 2013 Hi, I have an issue with a file when I plot only. The black 'mask' appears only after plotting. It does not show up in print preview. There are no frozen layers or switched off through viewports. When I open the viewport on a new paperspace page it follows me in. I can only assume there is an underlying mask in model space or paperspace. Thank you for reading my question and your help is very much appreciated. George. Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 2, 2013 Share Posted May 2, 2013 Can you attach a copy of a drawing that exhibits the strange behavior to your next post? Quote Link to comment Share on other sites More sharing options...
Cad64 Posted May 2, 2013 Share Posted May 2, 2013 Sounds like you may have a Wipeout in your drawing. Type WIPEOUT at the command prompt and then type "F" for Frames and then "ON" to enable the Wipeout frame to be displayed. Do you now see a rectangle where the black region displays on your printout? If so, select it and delete it. Quote Link to comment Share on other sites More sharing options...
