KennyJ Posted May 7, 2013 Posted May 7, 2013 Is there a way to create a new part from a part that I added cuts to at the assembly level? example: 1.) Add part number 12345 into an assembly. 2.) Add a cut to part 12345 at the assembly level 3.) Save 12345 part with newly added cut as new part number 54321 4.) Assembly tree now shows new part 54321 where 12345 used to be. Quote
KennyJ Posted May 8, 2013 Author Posted May 8, 2013 Anybody? I'm sure JD knows a workflow to do this task. JD where art thou? Quote
Bishop Posted May 8, 2013 Posted May 8, 2013 There is an add-in that you can find called Feature Migrator, that will take assembly-level features and add them to parts, but it's pretty finicky and error-prone, in my (limited) experience. It also won't save a copy of the part you've edited, I don't think. Easiest way to do it is right click on the part and open it, save-as with a different file name, then go back to the assembly and do a component replace, then you can edit it in-place in the assembly. Quote
KennyJ Posted May 15, 2013 Author Posted May 15, 2013 Thank you Bishop, I used the workflow you suggested and it worked just fine. Quote
