the style name cannot be changed globally. The style is applied to each text object as you create it or later if you desire. All you can do is change the font associated with that style - which is what you asked and have had replies to.
If you want to change a text object's style you should use qselect & the properties palette.
I went back and read everthing again and you are correct. I actually confused myself on this one. I tried several of the suggestions, and finaly something worked. Not sure which one, but I got the style to match the font. Romans/Romans.
Thanks for all the help with this, I certainly appreciate the responses.
Glenn
  • Replies 20
  • gsksun4
    7
  • dbroada
    3
  • totzky
    3
  • Strix
    2
Posted Images
