robnad Posted May 16, 2013 Posted May 16, 2013 I have a drawing with numerous copies of a particular block. I would like to change the Lineweight of the attribute so that it is reduced in all of the blocks in my drawing. How can I do this? Quote
pqphillips Posted May 16, 2013 Posted May 16, 2013 BEDIT is a good command to start with. Use it, select one block you want to change, make the change, close the block editor, then use ATTSYNC to make them all the same. Quote
