I am running AutoCAD 06, and I am working on a set of drawings from another office. When I open and save the drawing it takes a lot longer than usual. Is there something in the drawing that could cause this? Can it be fixed?
Thanks
S
Did you try purging the drawing? I've seen that happen before, check the file size to see if it is abnormally large. Sometimes purging doesn't work, and deleting layer filters doesn't work either, and the only thing that helps is copying the drawing to another template. So just try those things, and if it doesn't help, maybe someone else on this board knows a better trick than I do.
Hope it helps!
Are you working on a net? if so then make a copy on your local drive and when you finish just update the one that is stored on the net.
Also check to see if there are a number of layers turned off (and therefore invisible).
Does the file size reported by Windows Explorer seem in line with the drawing itself, or does it seem way larger than normal?
Are there XREFS? Type STATUS just before and after saving, see what resources are being used.
Nick
  • 1 year later...
I'm having the same problem:
I work from home and access the company's server by vpn connection. when I work on drawings at home, I save them locally, including x-refs. I then detach all images, redirect all x-refs.
In Options > files - i have ensured all files / file searchs are local (i've save all our blocks, linetypes, dimtypes, etc locally as well).
I assume acad is still trying to do something over the vpn.. even though the vpn is not connected.
what am i missing?
Thanks,
Dan
Im 90% sure bloated scalelists is the culprit here.
try -scalelistedit>reset>yes
dont forget the "-"
