Openantics Posted May 31, 2013 Share Posted May 31, 2013 Hello - i built a TIN surface by importing Point Files within the Definition pull down (vs importing points via the ribbon). I have made a lot of edits to the surface, including: adding and deleting points and included many feature lines with elevations inserted. From what I have read, these points are not objects in the drawing (ie, i cant pick them and review properties) so where do they live in my DWG? Obviously, the native text files i imported were not effected with the edits, so with that said, here is my question: 1. How do a to export all the points from the (a) surface into a single text file? 2. Is it possible to export along a grid? That is, export a point every 5 feet? When I select to display Points in Surface Style, I can see my 1M+ points, but sure would like to have a final text file!! always grateful, OA Quote Link to comment Share on other sites More sharing options...
Openantics Posted May 31, 2013 Author Share Posted May 31, 2013 some progress, but still need some help: i was able run the routine: Extract Objects, and selected Points. C3D then put all the points in my DWG, and i am able to click on them and open a properties dialogue box, but HOW do I export these points to a single text file???? There is an Export Points routine in the Output tab on the ribbon, but this just exports points that were imported. any other ideas? Help! Thanks, OA Quote Link to comment Share on other sites More sharing options...
