Hi, iam trying to refine my multibody/master part technique, i have run in to an annoying issue, when derriving from a master sketch, and only bringing the sketches i need for that specific part in to the part.
I can then create my 3d part model, but if I alter the master skecth it automatically brings in every sketch in from the master sketch, i then have to turn them off manually:x
what are your workflow when doing mastersketch/multybody work.
i hope some of the geniuses can help:)
I've never had that problem - it could be a bug?
Maybe you should post it on the Autodesk forums...
