Dear friend
I try it without ^c^c ,but i have same result and no different between them.
  • Replies 29
  • hosyn
    12
  • hmsilva
    9
  • ReMark
    3
  • MSasu
    2
Change de macro to
(load "C:/my doc/Ffjdshj.lsp" "Unable to find Ffjdshj.lsp")
the \\ in the macro is interpreted as a pause,
Henrique
dear hmsilva
I frequently change the / , \\ ,\ together and unfortunately at all of them i don't get good result:cry: but when i run (load ----) directly from prompt everything ok and lisp file run until i located it in toolbar button macro with ^c^c . ???
Command:
Command:
Command: (load "C:
("_>
("_> my doc
("_>
("_> Ffjdshj.lsp" "Unable to find Ffjdshj.lsp") "Unable to find Ffjdshj.lsp"
From the Autocad commandline, you can use
;;or
(load "C:\\my doc\\Ffjdshj.lsp" "Unable to find Ffjdshj.lsp")
but in a macro it must be
Henrique
Edited by hmsilva
Typo
I checked it with cad ver 2011 and 2014 and i don't receive good result -- i locate lisp file to support folder but .... ----i'm confuse :cry::cry:
hosyn,
this is a "déjà vu"...
the only way we can help you, is having access to correct information, is very difficult to keep on guessing, so...
copy and paste here, the command string you have in your custom toolbar, dont type. just copy/paste all the string.
Henrique
^C^C (load"C:/my doc/Ffjdshj.lsp"  "Unable to find C:/my doc/Ffjdshj.lsp")
the result after run above macro:
Command:
Command:
Command: (load "C:
("_>
("_> my doc
("_>
^C^C(load "C:/my doc/Ffjdshj.lsp"  "Unable to find C:/my doc/Ffjdshj.lsp")
Try the corrected string (removed an empty space between ^C and (load, and added a space between load and "C)
Henrique
Edited by hmsilva
Typo
Dear
hmsilva
Henrique
GREATTTTTTTTTTTTTTTTTTTTTT:):D:shock:
SOOOOOOOOOO THANXXXXXXXXXXXXXXXXXXXXX:):):)
IT'SSSSSSSSSSSSSSSS OKEY NOW.
You're welcome, hosyn
glad I could help
Henrique
